Small features being ignored
Posted: Fri Aug 26, 2016 8:33 am
by Vince
Hi All.
Have already searched for answer to this and non found. I have seen the printing guide that says features that are close to nozzle size may get ignored but i dont think its that.
I was trying to design a webbing buckle for a bike rack that had some small triangular teeth. They started off about 0.5 mm but I have been increasing the size (now 1.5x1.5) and they are still ignored. Have reset process to have 0.3 nozzle and they are still ignored.
I have made a small cube of 0.5mm sides and this slices ok (not actually trying to print that).
Why will it slice a cube of 0.5mm sides but ignore teeth on a part that are now 1.5mm?
Re: Small features being ignored
Posted: Sat Aug 27, 2016 11:05 am
Sounds like you may have a problem with the 3D model. Have you tried checking it using the S3D repair tools? Maybe you can post your factory file?
Posted: Tue Aug 30, 2016 8:13 am
by Vince
I figured out was happening. I was rotating the part to be flat with the bed but not'arranging' it after, therefore the first layers (which included the teeth) was below the bed and were not slicing.
