I wanted to print multiple copies of this: http://www.thingiverse.com/thing:23615. Problem is that some of the trurbines only got a brim for two of the three blades. It has nothing to do with too little gaps or something because you can reproduce it with only one turbine.
Test scenario:
- Download stl file and drop it on an empty bet in Simplify3D
- Rotate it at the z axis by 180°
- Add a brim: 1 skirt layer, 0 offset, 5 outlines
- Prepare to print: everything looks nice
- Reposition the object to x=70, y=140 (z remains 0, of course)
- Prepare to print: no brim for the outermost blade
The bed has a size of 200x200mm, so it should fit without any problems. Is this a bug or do I something wrong?
