no dimension check of xyz print coordinates?
Posted: Mon Aug 29, 2016 8:14 am
Hello,
Normally I love Simplify3D and won't miss it.
But now i have the problem, that the attached file produces negative X-coordinates, looks like this:
G1 X-0.526 Y94.686 E6.8050
The result of the printed file is not usable
Why i get no message about that? Is there a way where I can setup to get a warning or an error?
It is possible to get an info about min X/max X and min Y/max Y Info after press "prepare to print"
in the message about "Build Statistics"
I found the error by searching the .gcode-file for X- and then for Y-.
Thanks for help!
Regards,
Dirk
I'm using a Simplify3D Version 3.1.0 with an Ultimaker II Extended plus.
Thanks for help!
Regards,
Dirk
