Bug Report: Skirts and brims
Posted: Mon Aug 29, 2016 7:32 pm
So I discovered that if you have 2 processes going and one has a skirt and the other a brim AND they are both in the same y-axis General coordinates then you get brims on both parts.
Details:
I had a bunch of small identical parts that I had set up with default skirt; 1.6mm away from object single layer single line, that filled the build plate 3/4 of the way from front to back on my Prusa i3 mk2. Behind this array of 15 identical parts I added another , last piece of 16 units, of the same part and a single import of a unique part. On the 16 small pieces I used the standard skirt mentioned above but on the single unique part I used a 5-6 layer brim. The preview, and the hard output, made all parts with a 5-6 (can't remember exactly how many) line brim. I fiddled around and found that if I moved the 16th copy to an area in front of the front edge of the unique part's coordinates then the skirt and brim functioned properly.
In other words having a part with a skirt only on the same "row", in this case, caused the whole plate to brim.
Hope this helps solve this issue.
Details:
