ooze filter
Posted: Thu Sep 01, 2016 6:41 am
by eavogels
Hello.
I finaly managed to get my first print with ABS and HIPS on my Creator Pro 2016, ABS 230 degrees and HIPS 240 degrees.
The Ooze shield looks like you can see on this video:https://www.youtube.com/watch?v=SXTo5ZWl2B0
Is that how it is supposed to look? It's very fragile and on som spots the threads are not together.
I've never seen how an Ooze shield should look.
Regards, Eric
Re: ooze filter
Posted: Thu Sep 01, 2016 12:57 pm
by dorsai3d
They usually don't come out looking great, but you can probably get it a bit more solid than that. I'd recommend reducing the allowable sidewall angle change, and consider possibly adding an extra outline to the ooze shield if you still can't get the layers to stick to one another.
Re: ooze filter
Posted: Thu Sep 01, 2016 7:59 pm
by eavogels
dorsai3d wrote:They usually don't come out looking great, but you can probably get it a bit more solid than that. I'd recommend reducing the allowable sidewall angle change, and consider possibly adding an extra outline to the ooze shield if you still can't get the layers to stick to one another.
Thanks. I'll try that.
