Bug: pop-up window stops printing
Posted: Mon Dec 16, 2013 9:28 am
by Rob65
This is (not) so funny.
When Simplify3D is printing one job and I start preparing the next job in the Creator window, printing stops each time a pop-up window appears.
So when I want to import a part, the file open dialog stops my print job. Trying to configure a process: the pop-up window with the process settings pauses printing.
Etc.
Printing should be done in a different thread that is not interrupted by other work going on in Creator.
I tend to prepare a next job while printing the current one so this is almost a show stopper for using the build in print option.
Rob
Re: Bug: pop-up window stops printing
Posted: Tue Jan 28, 2014 5:40 pm
by jamesarm97
Is this on Windows or a Mac? I know OSX Mavericks has some smart power controls and will / can suspend a program from running if it is in the background. If on Mavericks you can right click on program and Get Info then select Prevent App Nap.
Posted: Tue Jan 28, 2014 8:27 pm
by Fozzie
I have experienced this too. I am on a Windows 64 bit PC.
Posted: Tue Jan 28, 2014 9:04 pm
by Rob65
This is on Windows.
When running both the machine control panel and the slicer, the machine control panel is not responding as soon as a pop-up window of the slicer is active.
Some of those pop-ups also pause printing, but not all of them.
The work around is to run the program twice, but then I loose the addition of the latest G-code files generated to the G-code library in the machine control panel.
Posted: Wed Jan 29, 2014 2:28 am
by Kenzu
I have this to on windows 8 :-( But normally i print from sdcard, so not a big problem.
