Extruder lag & advancing/retarding flowrate to machine moves
Posted: Mon Sep 12, 2016 5:25 pm
by 4DEE
Hi everyone :)
We have a screw extruder that we want to use to produce large coarse prints on a cartesian style CNC machine. The extruder is servo driven to match extrusion rate to print speed.
Nozzle diam is 10mm and the goal is to do 3-4mm layers at 2m/min.
There is a lag between input and extrusion which needs addressing. I see 2 ways to solve this:
1. Either advance the extruder (A axis), or retard the machine moves (XYZ axes).
2. Or (less preferable) forget about trying to match extrusion rate to print speed and just run the extruder at a constant speed and move it around at constant speed too (i.e. no slowing down at perimeters, corners, small radii etc).
Does anyone have any suggestions? Any help much appreciated.
Thanks,
Mike
Re: Extruder lag & advancing/retarding flowrate to machine m
Posted: Wed Sep 14, 2016 5:21 am
Maybe you can use the retraction extra restart distance to help prime the extruder
Posted: Thu Sep 15, 2016 12:16 pm
by dorsai3d
The typical solution for this (it is a problem on smaller extruders, though not typically noticed at speed) is to advance the extruder axis. You can take a look at this implemented in several different firmwares. Sailfish, Marlin, and repetier all have their own take on it, only sailfish has it enabled by default. For instance, there's some information in this github post: https://github.com/Smoothieware/Smoothieware/issues/645
Another way to do this would be to make pressure-based volumetric control, rather than assuming the extrusion volume is linear with extruder drive movement. It's really more a function of both pressure and speed, but no one has a good implementation that I've seen. I don't know if the big machines (like the BAAM) are doing this or not.
Posted: Tue Sep 20, 2016 12:34 am
by 4DEE
Thanks everyone :)
I found the slic3r "pressure advance" option and will have a play with this.
