Support not generated under some obvious parts left in air
Posted: Sat Sep 17, 2016 5:09 am
Hi
If you tak this STL http://www.thingiverse.com/thing:1775325 , (use the thicker base).
Turn it facing you
Resize for let's say a 4mm height
Now generate supprot with a width of 2mm. (3 and 4 give same result). 1mm works partually but not sure will be correct
The generated support leaves 2 quite obvious parts in the air :
First upper right tentacle (In the back)
First upper left tentacle (below mouth)
>> I can always add them, but how come those obvious ends are not being found ? All other slices do support them proper. This is reason I wished to report it to you more as a bug. I believe the issue is the tip of the tentacle is really thin and not detected as the end of a part...
Turn it facing you
