Ooze control (retraction distance etc.) should be a material option.
For ABS I need almost no retraction (0.5mm) but for PLA 1 ~ 1.5mm is a must.
So when I change the retraction distance for ABS, this should not change the retraction distance for other materials.
For me this is a must - I keep getting confused when options change for a different material.
The only work-around I found for this is to create different machines for the different materials I used - that way the retraction setting is kept with the material (machine).
