problem by printing a curve...
Posted: Tue Sep 20, 2016 5:44 am
by donClaudio
first, sorry that my english is so bad! - my printer is hephestos 2 and i am using simplify 3d. it works perfect, but only when i try to print a circle, the extruder prints in several STEPS and not that flow like it prints when i make straight lines and areas.... is this something that i have to select in the prefernces or is this a driver problem (windows 7 pro)?
Re: problem by printing a curve...
Posted: Tue Sep 20, 2016 10:50 am
by wirlybird
What is the model you are trying to print? How does the circle area look in the preview?
Posted: Wed Sep 21, 2016 6:45 am
by donClaudio
now i could locat the problem: i write the g-code in simplify and save it on a sd-card, put this into the printer - and it works perfect without troubles an faults! when is try to print the file with the usb-cable, i get this mistakes i told you in the first post.....???? can i be, that i have to change the settings in simplify and when yes - which one?
Posted: Wed Sep 21, 2016 8:13 am
by wirlybird
Seems it could be a communication issue. Things to check first are which USB port you are using. Change to another port especially if you are on a USB 3 port. Check-change USB cables. Do not use a cable over 9 feet and no extension cables.
Verify the USB driver set up with the manufacturer and also turn off any power saving features on USB ports. Also check the baud rate is correct.
Try printing from the software provided by the manufacturer.
Just some thoughts on things to try to eliminate.
Posted: Wed Sep 21, 2016 2:02 pm
by donClaudio
Thank you whirlybird! You wont believe it! It was the usb cabel! I had the same problem also on my laptop - changed the cabel and the issue was away!!!!!!!!
Thank you - klaus
Posted: Wed Sep 21, 2016 2:29 pm
by wirlybird
Awesome!!! Love it when the fix is simple and doesn't cost a bunch! Print on!!
