Toolhead stops over the filament after each layer
Posted: Tue Sep 20, 2016 6:23 am
by tyronemenezes
My toolhead this stopped on the filament after each layer. I tried to change the z lift retraction but it rises after this stop.
This downtime causes the toolhead each end scratch layer
Someone have the same problem?
i have a prusa i2
Re: Toolhead stops over the filament after each layer
Posted: Tue Sep 20, 2016 7:54 am
That looks like you just need to tune your retraction settings (and perhaps add a G28 X0 in your ending script)
Posted: Tue Sep 20, 2016 8:46 am
by HexHyte
Try to take look at "Coasting Distance" in the Extruder tab, maybe you set it a bit too high!
Posted: Tue Sep 20, 2016 3:38 pm
by dorsai3d
Sounds like your retract distance is too high and/or your retract speed is too low, and your print head is sitting still during the retraction. Try increasing the retract speed and decreasing retract length. You can also try enabling retract while wiping to keep the printhead moving while your retract is taking place.
