I use already relatively long enthusiastically S3D to create my printed parts.
Now however, I was at a point where I reached the limits many things and have iene solution sought to overcome these. I'm building me even very fast, stable and yet precise printer and they have more potential than I can ausutzen only with this Silcer. So I started with settings adjusted the various accelerations in the firmware directly to work in order to obtain better results and it works.
The lower stacking box PLA with 200mm / s printed with S3D geslicsd in vase mode, in 2.5h.
The upper box with adjusted acceleration values, the identical G-code manually accelerated by 12.5% and needed only 5 minutes longer.
I am not a programmer, but my question would be whether it would be possible to adapt on the FF settings of S3D accelerations the model as an additional adjustment. As my results, although the settings are of course complex, but still interesting
Greetings Edwin
