Gcode file always saved as .gcode
Posted: Fri Sep 23, 2016 8:24 am
by Strix
After a patch some time ago S3D forces .gcode format when saving. Even when overwriting a .g file it creates a new .gcode file.
This is a hassle since I'm using the printers auto print from SD card and need the .g format for it to see it. Its not a major problem but its an annoyance.
It worked before so I'm guessing its an oversight with a patch.
Re: Gcode file always saved as .gcode
Posted: Sat Sep 24, 2016 6:55 am
Did you try putting something like {EXTENSION "g"} in your post processing script? Otherwise, if you have gcode selected as the export file format, I'm pretty sure it will always save a .gcode file like you said
Posted: Sun Sep 25, 2016 4:09 pm
by Strix
Worked great!
Thanks alot.
Posted: Sat Apr 18, 2020 1:23 pm
by rsworden59
In my experience, if there are multiple Processes, the {EXTENSION "g"} has to go in the "Additional terminal commands for post processing" box of only the FIRST process, the one that handles the first layer. It's ignored in upper Processes.
