Better Profiling Feature Should be Revised
Posted: Tue Sep 27, 2016 4:25 am
The current profiling are kind of in a mess and not to mention that there are several type of different filament requiring different speed especially for the flexible filament.
The current material profile only affects the temperature and extrusion while quality is only infill and solid layer section.
Not only that, I would like to add an another button feature "default" or "Reset Profile". The current software which is 3.1, after modifying the profile, it will add "modified" at the profile name and upon exiting and loading another session of the application, the parameter stays the same making the user had to select another profile just to reset the preferred profile back to its last saved state before being "modified". In addition, a checkbox in the option area should be added with something like "retain modified profile setting upon exit".
Profile renaming should be there as well to rename the profile according to the user preference
In summary of feature for these profiling improvement I will list them here
- improve process window corresponds to their profiling
- Add "Reset Profile" button to revert
- Add "Retain modified profile setting upoon exit" in option settings
- Profile renaming
- Better profiling in overalls
