Hello,
I have recently switched over from Cura and am liking the results so far. The one difference I noticed is that in Cura, the "brim" would generate on all parts of the object. For example, if I was printing a big square with a circle/hole in the middle of it, Cura would generate brim around the outside of the circle and on the inside of the circle within the perimeter of the square. If I wanted it only on the outside of the square, I'd select "skirt" and set the offset small.
In S3D I can't find a way to generate the brim on the inside - it seems to only generate on the outer most perimeter of the model. In most cases, this is fine. But I do have some prints that require the extra support within. Consider a face plate with a large cutout for a screen. Without the brim on the inside, the inside edge of the screen lifts off the bed.
Am I missing an option somewhere? Thanks!
