Slow heating of HBP and Extruder
Posted: Thu Sep 29, 2016 11:23 am
by freiser77
Hello,
I own an Flashforge Creator Pro (2016). When I preheat the HBP and the Extruder, both heat at the same time.
When I load the x3g-file generated by Simplify3d, then the extruder temperature drops till the HBP is fully at its temperature. After that the extruder starts to heat up. Is there a possibility to start heating, both extruders and the HBP at the same time? Please note: I want the printer to wait till all temperatures match.
Thanks for your help
Florian
Re: Slow heating of HBP and Extruder
Posted: Fri Sep 30, 2016 5:26 am
Just search the forum. There's dozens of threads with the exact same questions (as well as the reason why this isn't enabled by default)
Posted: Fri Sep 30, 2016 7:34 am
by wirlybird
My FFCP's are the same way and off the top of my head I would say it is to prevent overloading the power supply. With high draw electronics there is usually a good reason for the way it is set up. It could be overboard on safety but do you want to find out by having a melt down and possible fire?
Posted: Fri Sep 30, 2016 3:49 pm
by freiser77
I now have found the G-code commands I need. Thanks for your help.
To the point of overheating: As I am having the 2016 version and the FlashPrint-software delivered with the printer as well as the printer itself heat everything up at once, I think, that the power supply is capable of handling the loads. So I've set the heating to simultaneous.
Posted: Mon Oct 03, 2016 7:10 am
by magick81
That was the first thing I noticed when I switched to s3d.
I'm an impatient ass, so I just use the FFCP's preheat function to heat the printer up so speed up the waiting. :)
