MODELS SUBJECT TO PRESSURE (35-42PSi) SHRINK
Posted: Thu Oct 06, 2016 11:24 am
by jamado
I´m producing my dental models for making dental aligners on my UM2+ wich by the way works perfect. I use PLA spool and infill of 25-30% but when trying to make the aliogners on the vacuum machine they shrink. Shoul I increase the infill? or any other change in the process to avoid this ?
Re: MODELS SUBJECT TO PRESSURE (35-42PSi) SHRINK
Posted: Thu Oct 06, 2016 12:41 pm
by dorsai3d
What temperatures are you using with the vacuum machine? I would think that PLA would hold up okay to 40PSI external, but if it's at elevated temperatures (45°C+) then it could well be weakened enough to deform. This would be a good case to look into using HTPLA and annealing or switching to a higher temperature material altogether.
Posted: Mon Oct 10, 2016 1:18 pm
by jamado
Thanks for your reply an yes the vacuum is above 60C in temperature. Do you know a HTPLA brand ? One you've used? Thanks again
Posted: Mon Oct 10, 2016 1:36 pm
by zemlin
Is there a reason you want to stick with PLA, or can you consider other materials with better thermal stability?
Posted: Tue Oct 11, 2016 9:32 am
by dorsai3d
I don't have direct experience with elevated temperatures with this, but I'd recommend looking into something like this:
https://www.proto-pasta.com/products/high-temp-pla-v2-0. Make sure that you heat treat it before using it in service, though.
Alternatively, you might be able to print a negative and cast it in another material (thermoset? plaster?) that holds up better.
