Rebekah_harper
Change filament fucntion
Hiya,
I would like to see a change filament fucnction on the machine control panel.
I tried to do this but when I pressed resume it spat it out resetting to the pre pause state.
allowing a user to change to a new spool when the one in use is or has run out.
I try and use the short bits and have to add it manually during print on my UM2+
but if I could pause the print and be able to add it under a Chang/add filament function that would be great.
Becky
Re: Change filament fucntion
You might want to change to relative extrusion distances if you are going to be swapping and jogging the filament around a lot. That will probably work better for this
Rebekah_harper
Hiya,
not sure what you mean by 'relative extrusion distances' I have no problem with any aspect of the extrusion. what happens is that any movement i do whilst I have paused the print is reversed on resume.
It's a setting on the G-Code tab
