Manual Support Definition & Generation
Posted: Sun Oct 16, 2016 7:02 pm
Here's the results of a brief investigation I've done on the definition and generation of manual supports.
I set the test up with the following basic parameters:
Nozzle diameter = 0.2mm
Extrusion width (manual) = 0.2mm
Support Infill %age = 100% (initially)
Extra Inflation Distance = 0
I created an "L" shaped block 10mm wide and 20mm both high and deep..this shape then tipped on its nose to form an overhang.
I then added three single columns of manual support, 1mm, 2mm & 3mm left to right...as shown here (with z cross section to make things clearer) : Observation: The simulated columns are shown smaller than the defined size! The grid on the bed is 0.1mm
Slice and the Preview view is: Observation: So far so good. Support generated to cover the full cross section of all three columns...5 lines for the 1.0mm, 10 for the 2.0mm, and 15 lines for the 3.0mm.
I now lowered the Support Infill %age to 50% and resliced: Observation: We now have half the number of strips....well almost. Rather than 2.5, 5 and 7.5 (which is not possible), we have 3, 5, and 7. Still looks sensible.
Continued in next post as only three attachments allowed per post.....
