Unexplained speed increase on fine detail test
Posted: Tue Oct 18, 2016 1:32 am
I have a Prusa i3 MK2 using the profile provided by Prusa. I'm printing the Make Fine Positive Detail test. Things to downhill near the end of the test and a big mess of blobs is made at the tips. I have narrowed the problem down to speed increase at the peaks.
As you can see things are going along at 1.6 mm/s about 3/4 of the way up when it shifts to 40 mm/s(the default printing speed) at the end. I makes sense to me that there is a shift from green at the base to blue as it goes towards the peak. But I don't understand why it then goes to maximum speed.
I have been able to override the speed by breaking the print up in to two processes and lowering the default speed of the second process. But I would love understand better the root cause. I am new to 3D printing and I would greatly appreciate any insights you can provide.
