under extrusion???
Posted: Mon Oct 24, 2016 9:19 am
Had an issue start after changing filament. Ive printed this model perfect 5 times, then I had to change filaments. (Hatchbox to Gizmodorks 1.75mm PLA) Usually i dont run into this. Is this a setting issue? I didnt change any between filament changes. I'm stymied
https://goo.gl/photos/ZDHj7brZsDB3rogA6
Re: under extrusion???
Posted: Mon Oct 24, 2016 9:48 am
by zemlin
Not much detailed info to go on here, but have you measured the diameter of the two filaments? Different brands of filament don't always run apples-to-apples. Might try increasing the extruder temp 5-degrees with the new filament to see if that helps.
Posted: Mon Oct 24, 2016 11:00 am
I noticed that S3D was printing some odd lines and just not acting right, so I closed it out, and re started the program. I started the print again and all seems to be right in the world now. Perimeters are solid once again and the bottom layer is solid as well, no gaps in the layer so far. Finger crossed
