Page 1 of 2
Printer printing wrong model
Posted: Tue Oct 25, 2016 12:45 pm
by mertseger
I had a problem with model and I press emergency stop and disconnect printer (malyan180). Next time I insert new model to S3D and send it to printer (printing over USB). Although in preview mode S3D is showing that I am printing chess figure ( which I want to print), printer is printing a vase that was previous model. And this happens second time already. What am I doing wrong ?? (I send mail to support first time but there is no answer from them).
Re: Printer printing wrong model
Posted: Tue Oct 25, 2016 1:49 pm
by wirlybird
After pressing E stop try to power off then on the printer then reconnect and load the new model. Maybe it is storing the info already sent and needs to clear it. Not familiar with the printer so it is a guess.
Posted: Tue Oct 25, 2016 2:20 pm
by mertseger
Yes thanks I figure out that he saved that model but where should I delete it, I dont see it anywhere?
Posted: Tue Oct 25, 2016 2:37 pm
by wirlybird
Aside from trying to cancel the print from the printers panel I don't know how.
Posted: Sat Apr 01, 2017 6:47 pm
by Heptagon
It did take me some time to solve this.
Some printer requires to generate a *.x3g output and will use that for printing.
In the current version, this file is not deleted during rendering another object and the printer will further on just print the wrong object.
I solved this by deleting temp x3g files, executing this command in command shell
del %USERPROFILE%\AppData\Local\Simplify3D\S3D-Software\*.x3g
or brows to the path
and delete the x3g files manually.
I hope this helps.
Posted: Mon Apr 03, 2017 7:10 am
by wirlybird
thanks for updating so others can see this.
Posted: Mon Apr 16, 2018 5:29 pm
by svangeldern
When I delete the temp.x3g file I get this error when I try to begin a print
"This machine does not support plasintext.gcode files.
It appears that a current temp.x3g file is never created.
I'm trying to print on a Makerbot Replicator II.
I created an .x3g file with the makerbot software.
Moved it to the S3D-Software folder and then renamed it "temp.x3d".
S3D printed this file.
It appears S3D is not creating a temp.x3d based on the current FactoryFile.
This has happened on occasion in the past but now it happens every time.
Any ideas?
Posted: Tue Apr 17, 2018 7:36 am
by rrdavis
What happens if you click "Save Toolpaths to Disk", and then save the .x3g file to a new location on your hard drive? Does the new file show up?
If it does, then just go to Tools > Machine Control Panel, connect to your printer, and then click the Print button in the top left and select the new file that you just exported.
Posted: Tue Apr 17, 2018 10:00 am
by svangeldern
rrdavis,
It saves a new *.gcode file.
*.x3g is not presented as a file type option.
Thanks,
Steve
Posted: Wed Apr 18, 2018 4:41 am
by rrdavis
Well that would explain your problem! Go back to Help > Configuration Assistant, select the MakerBot Replicator 2, then try to export the print files again. You should see both a .gcode and .x3g file.
