First layer Issues
Posted: Wed Jan 22, 2014 1:54 am
by MrWayne
Hi All...
As a new Simplify3D User, I'm baffled about this issue.
The first thing that is laid down is a ring which encompasses the actual print. Then the head starts to build the print within this ring.
However, in a few cases the head will build over the top of this ring. (see picture)
I am wondering how to turn off this outer ring to prevent it from causing issues.
Thanks..!!!
Again, forgive the New User syndrome.
Re: First layer Issues
Posted: Thu Jan 23, 2014 2:34 pm
by tri-lite
We all have had first layer issues. But you learn something on each print, so keep experimenting!
That outer line is referred to as a "skirt". Skirt settings can be customized in the software. However, most of the time, you DO want a skirt. The skirt allows your extruder to get cleaned out and start extruding a very clean line of filament. It also allows you to make sure your layers are adhering nicely to your bed. A successful skirt leads to a successful first layer (or at least improves your chances!)
Locating the Skirt settings:
Open the FFF dialog box by double-clicking on your added process (bottom left panel of software).
Make sure to click on "Show Advanced" to get access to all the controls available.
Click on the Layers tab (refer to the attached image 1) and find "Skirt" settings at the bottom right.
The standard settings work just fine (2 layers, 4mm offset, etc.)
You will only see your skirt in the Preview mode. You can see my skirt in image 2.
Now, let's get to the root of your problem, which probably involves more than the skirt. I would bet your problem is about getting your first layer to stick well. It appears your skirt did NOT adhere fully, which caused a portion of the skirt to get intertwined in the actual part itself.
There are lots of posts about getting your first layer to stick, so now that you know all about skirts, I'll let you read more about first layer adhesion in other posts.
Posted: Fri Jan 24, 2014 6:03 am
by MrWayne
Thanks for the reply.
I have increase the skirt parameter to 10mm. Now it stays well away from the print..!!
Thanks..!!!
