Imported profile does not update machine def / g-codes
Posted: Tue Nov 01, 2016 5:18 pm
by toybuilder
I just updated to the latest version of S3D and also attempted to add a new machine profile -- when I do it, the start G-code is not getting updated, nor the machine size definition. This worked on the previous version on a different PC, and the only variable that I can see is that I just updated to the 3.1.1 before doing this new import. Does anyone else have this issue?
Re: Imported profile does not update machine def / g-codes
Posted: Wed Nov 02, 2016 5:44 am
Well are you sure you have the overrides turned on in the process settings? Maybe it would help more if you posted a few files. Maybe a factory file or your FFF profile with the process that isn't updating your build dimensions correctly. Otherwise it's hard to give suggestions
