[ADDED] independent axis scaling
Posted: Sun Jan 26, 2014 5:12 am
by Zeeflyboy
Unless I missed it, currently it is only possible to scale the model globally with a fixed aspect ratio.
Can we get the option to scale each axis independently? When adjusting for ABS shrinkage for example I find 1% works well in X and Y but isn't required in Z... in some tight tolerance parts the fact I have to scale Z as well means it doesn't fit well.
Re: feature request - independent axis scaling
Posted: Wed Jan 29, 2014 5:12 am
by Flateric
I would also very much like to see this added.
Posted: Thu Mar 13, 2014 1:41 pm
by rsilvers
This is still not in the 2.0 version. It would be very useful, and seems easy to add.
Posted: Fri Mar 28, 2014 4:14 pm
by Dssguy1
MakerWare has this functionality and it is awesome! You can use it to shrink one axis and not bother the others. I use it all the time to make things like block letters larger in the X and Y direction but not super thick like they would be if I increased all axis.
Generally I bump up the scale to 200%, then I uncheck the "Uniform Scaling" box in MakerWare and bring the Z-Axis back down to where I want it. Again, this seems like a pretty easy thing to implement, but also very powerful for making simple size modifications to our designs.
+1
Posted: Thu Jul 09, 2015 8:47 am
by S3D-Jason
Non-uniform scaling was added in version 2.1
