[ADDED] Vase Mode in multi-process prints
Posted: Tue Nov 08, 2016 6:26 pm
by bludin
Currently, S3D refuses to generate multi-process code if one or several processes are in vase/corkscrew mode.
As far as I can see, there is no real reason for this severe restriction, if the processes use different height regions. Thus I propose that it be removed.
Please
Re: Vase Mode in multi-process prints
Posted: Thu Dec 15, 2016 5:56 pm
by daduck748
+1
I have a square tube test object for testing filament, as seen in many YouTube videos. I designed it with 0.4mm wall thickness and when I print it, I walk away, not realizing it takes about an hour and a half to print this 40mm tube. I looked into it and realized it was printing 2 shells at 0.4mm. I looked online and the best solution was to make a solid and print 1 shell, no infill. Doing it this way reduces the tube test to about 20-30 minutes but it kinda blows when the vase mode is sitting right there.
Posted: Mon Mar 13, 2017 4:31 pm
by OnlyTono
+2
I have a need to print multiples of the same part, and the best results for this part is using Vase Moe (or corkscrew mode)
What I need, is to be able to print multiple consecutive copies on the same print job.
Each copy takes about 1.5-2 hours to print, which means I have to be present to start the next one. With the ability to print them consecutively, I could setup 4 or 5 of them staggered on the print bed. Hit the print button and come back 8-9 hours later and have 4-5 perfect prints.
Posted: Thu Jul 27, 2017 11:38 am
by S3D-Jason
As of version 4.0, vase mode is now supported in multi-process prints. In fact, there's actually a picture of this setup at the bottom of the page below:
https://www.simplify3d.com/software/rel ... ion-4-0-0/
Thanks for the great suggestion, and I hope you find some creative new uses for vase mode in your prints!
