Separate printing speeds for each extruder
Posted: Sat Nov 12, 2016 5:25 am
by Cadvision
If you want print Ninjaflex and PLA on same print, you need 60% slower speed for flexible layers and if that same layer has also pla areas then the different processes for different layers is not an (good) answer. Repetier-host has independent speed settings for each extruder. Can you add this feature to Simplify too?
Re: Separate printing speeds for each extruder
Posted: Mon Nov 14, 2016 8:39 pm
by jballard86
I use multiple processes for the same layer.
for example I separate Support material as a different process. you could even do perimeters as a different process, or infill.
