Skirt/brim around single objects in multi object print?
Posted: Sat Nov 12, 2016 10:23 am
Hi
I am having problems with printing large amounts of small objects in ninjaflex. Due to the nature of this material, its hard to prevent oozing.
Therefor the start of each new object will have to deal with a blob thats partly set. If I could make sure that every single process starts with a brim, this problem would go away. Unfortunately I can't it seems. Regardless how I set it up, the software makes the brim around the entire printarea. If I reduce the distance and space the parts, the program still prints all separate brims before starting the first part. This makes no sense as the printjob is set up as a sequence. (Pain in the A** to do in S3D compared to Cura or Slic3r)
Why these obvious shortcomings in a software that has some really sophisticated functions overall?
