Lithophane
Posted: Tue Nov 15, 2016 10:05 am
by nickm324
Anyone have the process and settings to create a Lithophane in Simplify3D?
I tired the import image addin but after I went through the steps the screen was blank there was no model on the platform and there were no errors reported.
Re: Lithophane
Posted: Wed Nov 16, 2016 6:03 am
I just created a PNG file and used the image to 3D add-in. Worked fine for me. Maybe try using a PNG if you were previously using some other file format
Re: Lithophane
Posted: Thu Nov 17, 2016 6:12 am
by nickm324
Yea I converted my image to png and it converted and imported it. Guess the addin doesn't support anything but PNG.
Now does anyone know what settings to use for layers, angles, etc... to get a good print?
Re: Lithophane
Posted: Fri Nov 18, 2016 9:04 pm
by MikeO
From my experience:
Use 3 solid layers on the bottom, so the brightest part of the image will have that much under it to support it at a minimum, for strength.
Use 100% infill for the remaining layers.
Depending on the transparency of your filament, distribute the image on top of the bottom layers over about 30 layers. You want the highest number of layers you can live with to give the maximum number of different levels of brightness. Thinner layers will let you use more of them.
If you use too many layers the image gets dark and contrast goes down.
Good luck!
Re: Lithophane
Posted: Sat Aug 26, 2017 12:42 am
by nerys
I get the best results making it 3mm thick (good detail decent contrast) I print vertically
this means at most 7 or 8 layers.
I just print with 0% infill but set permiters to 8 and use single extrusion infill
comes out very nicely. I have not tried doing this with simplify 3d generator (thank you for that answer IE using PNG :-) I will try it tonight.
Re: Lithophane
Posted: Sat Aug 26, 2017 8:50 am
by MasterFX
I recently printed a lithophane using the online generator http://3dp.rocks/lithophane/ which has much more options. Then I printed with 100% infill in S3D @ 0.2mm Layer.
The result is stunning
Re: Lithophane
Posted: Tue Aug 29, 2017 2:23 pm
by jfkansas
Would be perfect for a Trump picture.
Re: Lithophane
Posted: Tue Jan 09, 2018 11:53 pm
by jccbsl
I'm looking for a way to print a 1/2" to 3/4" tall base frame at the bottom of my lithophane so the image is positioned higher in the freestanding holder I printed. Any suggestions?
Re: Lithophane
Posted: Sat Jan 13, 2018 2:56 am
by rrdavis
S3D can generate lithophanes from an image, and it allows you to set the height of the base panel. Go to Add-Ins > Convert Image to 3D.
