Blobs and Zits & object orientation
Posted: Fri Nov 18, 2016 9:01 am
Hi
I have model of wind turbine. Today I printed tower.
First problem are blobs on start of every layer. Retraction distance is 1 mm. I have change extra restart distance for -0,2 as it is written in print quality troubleshooting guide for Blobs. But then I got other problem it seems there is too little plastic on start and there are even some holes in outer layer (seen of figre 1 (not the holes they are a little higher). I clear extra restart distance back to 0 mm and retraction distance is 1 mm. I get this blobs in every layer on the start (figure 2).
I selected start point for layer so all the blobs are in line (it is easyer to remove them).
1. What else can I change to remove this blobs?.
2 Question.
How would you turn this rotorblade to print it best. If I rotate it 90 degres I have to put supports below and it gets realy ugly.
2 Question.
