Page 1 of 2
Why is it not full filled?
Posted: Sun Nov 27, 2016 6:03 pm
by mroschk
Hello,
as you can see in the Picture added, between the Skirt Lines are no space.
But between the first Layer Lines are a Space. ( mrked with the Red Arrow )
This Space between the Lines are also in the printed Model and i dont want that.
I checked the Parameters, but i dont know what Setting is responsible for that Space?
Can anyone help?
Matthias
Re: Why is it not full filled?
Posted: Sun Nov 27, 2016 6:04 pm
by mroschk
finished part...and fff file
Posted: Mon Nov 28, 2016 10:13 am
by kabali16
S3D handles filling the gaps in a different way. especially when it has to do with outlines, you need a complete outline/perimeter to fill in the gap. Since it cannot fit another rectangle in that gap, it leaves it open. Set your First layer Extrusion width to something thicker like 120-150%. This will close the gap at least in the bottom surface.
Posted: Mon Nov 28, 2016 11:09 am
by mroschk
Hello,
thanks for the reply.
But did you look in the FFF File i attached?
If i am right, and this is what you mean, i have 150% for the first Layer.
Matthias
Posted: Mon Nov 28, 2016 12:40 pm
Try setting your first layer width to 120% and Thin Wall Behavior to Gap fill at 50%.
Posted: Mon Nov 28, 2016 1:36 pm
by mroschk
Hello,
i changed the "Extrusion Multiplier" back to 1.0.
Now it seams to work. Maybe that was the reason.
Matthias
Posted: Mon Nov 28, 2016 4:45 pm
by kabali16
I would not recommend messing with the extrusion multiplier - this should be used only to compensate for over or underextrusion.
Try what Doug recommended. I set the First layer width to 100 and thin wall behavior to 50% and got 2 outlines complete.
Posted: Mon Nov 28, 2016 4:48 pm
by mroschk
Hello,
ok, i will do that ( but tomorrow :-) )...but i dont understand the second part:
What must i here do and where ? I search for a "GAP Fill " Settig, but did not find that.
Sorry...i am a bit new in S3D
Matthias
Posted: Mon Nov 28, 2016 5:09 pm
by horst.w
Tab Advanced:
Posted: Mon Nov 28, 2016 5:11 pm
by mroschk
Ahh...over there...i am so sorry...
I try it tomorrow and come back with a Report .. Thanks
Matthias
