Hello,
Instead of a coasting move, would it be possible to add a feature that lets you define how many mm's in advance (before a printing move happens), the retraction needs to take place?
I assume this would work a lot better than coasting because it would cut off the flow rate immediately in a precise way, instead of just letting the pressure leak out slowly.
