Filament jam
Posted: Tue Dec 06, 2016 7:41 pm
by joestefano
My filament is jamming while printing the attached model. I have printed it twice and it jams at the same place. I'm thinking that the distance of travel between the square posts is allowing the filament to cool and jam. After canceling the print the jam is easily cleared by retracting and extruding a couple of times. What setting can I adjust to help with this issue? assuming my theory is correct. I am using a direct drive extruder setup. PLA at 230C.
Re: Filament jam
Posted: Wed Dec 07, 2016 7:31 am
Re: Filament jam
Posted: Wed Dec 07, 2016 1:12 pm
by kabali16
joestefano wrote:My filament is jamming while printing the attached model. I have printed it twice and it jams at the same place. I'm thinking that the distance of travel between the square posts is allowing the filament to cool and jam. After canceling the print the jam is easily cleared by retracting and extruding a couple of times. What setting can I adjust to help with this issue? assuming my theory is correct. I am using a direct drive extruder setup. PLA at 230C.
Check and lower the retraction distance. Which printer is this ? What hot end does it use ? PLA at 230 is pretty high. possible heat creep
Re: Filament jam
Posted: Wed Dec 07, 2016 1:46 pm
by wirlybird
If you are at 230 for PLA and moving a long distance without any extrusion I think heat creep is suspect. Also retraction settings to long and to fast can add to it.
Re: Filament jam
Posted: Wed Dec 07, 2016 4:46 pm
by joestefano
kabali16 wrote:joestefano wrote:My filament is jamming while printing the attached model. I have printed it twice and it jams at the same place. I'm thinking that the distance of travel between the square posts is allowing the filament to cool and jam. After canceling the print the jam is easily cleared by retracting and extruding a couple of times. What setting can I adjust to help with this issue? assuming my theory is correct. I am using a direct drive extruder setup. PLA at 230C.
This is a CubeX printer converted to Duet electronics. I am using E3D hot ends. I normally print this PLA at 210-220 I raised it to see if it would help. Can you take a look at my FFL and suggest retraction changes. How do I combat "heat creep"?
Re: Filament jam
Posted: Thu Dec 08, 2016 10:18 am
by kabali16
As long as the e3d is assembled correctly, it will not cause any issues. Is it the genuine or a cheap clone ? Is the hotend fan running continuously ? Is the direction of the fan (physical) set correctly ?
Sure, post your FFF.
Re: Filament jam
Posted: Tue Jan 03, 2017 5:40 pm
by joestefano
I may or not have done a stupid thing. I installed my heat break into my heat sink with thermal epoxy (original E3D hot end) I now have a heat creep problem on 1 out of 5 hot ends. Thoughts????
