"WARNING: CRC mismatch detected" error when connecting
Posted: Wed Dec 07, 2016 2:57 pm
by legosrock
Hello, I'm trying to connect to my robo 3d r1. The only baud rate that doesn't immediately fail is 250000. however, after connecting, this gives me this error: WARNING: CRC mismatch detected
What do I need to do to connect correctly. I am kinda a novice at this, so any help is appreciated. thanks.
Re: "WARNING: CRC mismatch detected" error when connecting
Posted: Thu Dec 08, 2016 5:27 am
by brian442
You could try disabling the "wait for startup command" option on the Communication tab of tools > firmware configuration. Otherwise, you may also want to post your communication log here so others can try to guess what else to change from that
Posted: Thu Dec 08, 2016 9:48 am
by kabali16
legosrock wrote:Hello, I'm trying to connect to my robo 3d r1. The only baud rate that doesn't immediately fail is 250000. however, after connecting, this gives me this error: WARNING: CRC mismatch detected
I have had luck with a new short usb cable with a ferrite collar, like the one you get with arduino kits. Also, make sure the usb cable is not wound or coiled around any conductive object
Posted: Wed Jan 25, 2017 2:48 am
by the_arrest
brian442 wrote:You could try disabling the "wait for startup command" option on the Communication tab of tools > firmware configuration. Otherwise, you may also want to post your communication log here so others can try to guess what else to change from that
This worked a treat for me. Cheers for the heads up
Posted: Thu Apr 20, 2017 8:00 pm
by jarm00725
the_arrest wrote:brian442 wrote:You could try disabling the "wait for startup command" option on the Communication tab of tools > firmware configuration. Otherwise, you may also want to post your communication log here so others can try to guess what else to change from that
Thank you, this worked for me !
