What happened here? (Photo)
Posted: Fri Dec 09, 2016 9:35 am
by RomeFallsAgain
Never had this particular issue. Seems everything was going fine then this.
The bottom 1/2 inch or so printed normally, there should have been another inch that looked exactly like the bottom part that printed ok.
Instead the upper last inch came out as a bird's nest.
This exact same file printed fine previously so I don't think it's the x3g file
Photo verified working on several independent devices.
If you can't see it please check your computer or device for blocks or issues.
For example, the NoScript add-on for Firefox will block forum images
Re: What happened here? (Photo)
Posted: Fri Dec 09, 2016 10:43 am
by 3Drasle
Photo ?
Posted: Fri Dec 09, 2016 11:13 am
by RomeFallsAgain
3Drasle wrote:Photo ?
Hmmm..not sure why you can't see it?
I just checked the photo link with someone elses phone and it showed up just fine.
Posted: Fri Dec 09, 2016 4:46 pm
by zemlin
My first guess would be a partially clogged nozzle.
Posted: Sat Dec 10, 2016 11:07 am
by kabali16
My guesses :
- clogged nozzle
- tangled filament in the spool
- spool is not spinning freely
Posted: Sat Dec 10, 2016 11:39 am
by RomeFallsAgain
Thanks for the suggestions.
I'm going to disassemble the extruder this weekend and see if there's a clog.
What causes a clog at the nozzle? Never had one before in over 1000 hours of printing.
I would have though that anything that makes it as far as the nozzle would just melt and go through (assume it's PLA or some meltable material)?
Posted: Tue Dec 13, 2016 4:22 pm
by kabali16
quick google search gave me this link
https://pinshape.com/blog/5-causes-of-a ... to-fix-it/
