Extruder leaves bed
Posted: Thu Feb 06, 2014 5:22 am
Hi everyone,
For some reason, my extruder decides to leave the bed (in terms of the xy plane) at the beginning of a print (after going to the origin), push out a little bit of filament while floating off the bed, and then come back to begin the actual print. The interesting part is that if you run the g-code for the item I'm trying to print, the simulation shows that the extruder will in fact leave the bed, and I can't figure out why.
G-code is attached. I made the model in Inventor Professional 2013, saved as .stl, then imported to Simplify 3D 2.0.1 and generated the g-code. The printer is a MakerGear M2. This has never happened before I updated Simplify 3D (I was on a relatively old version).
I would greatly appreciate any help.
