[ADDED] Exterior fill, more angles needed
Posted: Tue Dec 13, 2016 7:24 am
by ukpete
Currently only rectilinear or concentric fill patterns are available for exterior fill, with rectilinear only at 45degrees.
I need to have exterior angles available of at least 0 and 90. I print special purpose railway sleepers in gauge 1. and need the fill lines to look more like wood grain i.e. along the length of the sleeper (tie if you are in USA).
Re: Exterior fill, more angles needed
Posted: Sun Jul 30, 2017 1:01 pm
by S3D-Jason
This feature is now available in version 4.0. You can now customize the exact angles that are used for the external fill. For example, if you wanted to use 0/90 instead of +45/-45 (the default), you could easily make this adjustment.
To do this, click "Edit Process Settings", go to the Infill tab, and adjust the External Infill Angles as needed
Thank you for the suggestion!
