3D Printed RC Plane Issue
Posted: Fri Dec 23, 2016 5:16 pm
Hi Guys,
I am printing a 3D printer radio controlled plane from the folks at 3DLabPrint.com. They provide ready to print S3D factory files for all the parts that a gule together post priting.
After some attempts I managed to get it to a reasonably good quality using 2.85mm White PLA Filament.
I would like to print in either silver or clear filament. I had no success with the clear filament at all so changed to silver. The clear filament seemed to melt a lot, block the nozzle and under extrude a lot.
I am also not having success with silver. I seems to be under extruding on some lines but not others, but I can't figure out what is going wrong. I have attached photos and the modified factory file (with no models in it to reduce size). I am also printing this file at 65% speed on the printer. The filament is on the ground on a smooth rolling spool to reduce friction.
Photos and S3D files are here: https://drive.google.com/drive/folders/ ... sp=sharing
Any help would be greatly appreciated.
Thank you.
Regards
Jason
Thank you.
Regards
Jason
