BruceG
Tronxy X3
I'm building a tronxy X3 kit. Does anyone have settings for this machine?
Re: Tronxy X3
Did you try using the configuration assistant and choosing Other and then filling in your machine specs?
BruceG
Re: Tronxy X3
CompoundCarl wrote:Did you try using the configuration assistant and choosing Other and then filling in your machine specs?
Thanks, I'll try that but was hoping that someone had worked through all the details I'm unfamiliar with as this is my first Bowden machine.
kabali16
Re: Tronxy X3
You will get most of the information from the product page or manual if you had gotten any
1. googled the printer and looks like Prusa model, so choose Reprap/Marlin firmware. so choose that
2. Build volume, nozzle size and filament diameter will be there in the product page
3. if your machine has a heated bed, click that check box
4. no. of extruder based on the config you have
5. Baud rate is usually 115200 or 250000
More info available here -> viewtopic.php?f=8&t=2009
Kabali daww!!
Prusa i3 | Kossel
Shift_Dog
Re: Tronxy X3
Greeting from Sin City. I'm having connection issues, hope I'm in the right place but I just purchased S3D and cant connect to my Tronxy X3A. I know I have the correct com port and baud rate. I have not had any issues with Repetier. I have been using the printer with great success. However if I try to connect through the "Machine Control Panel" I get a cant connection failed message.
Attempting connection at \\.\COM5...
Testing plaintext communication protocol...
Testing binary communication protocol...
READ: start
READ: echo: External Reset
READ: Marlin1.0.0
READ: echo: Last Updated: Apr 6 2017 20:19:33 | Author: (none, default config)
READ: Compiled: Apr 6 2017
READ: echo: Free Memory: 11889 PlannerBufferBytes: 1232
READ: echo:Stored settings retrieved
READ: echo:SD card ok
READ: ok
Testing alternate communication protocols...
WARNING: CRC mismatch detected
READ:
Connection failed.
I even went as far as to update my bios and usb drivers and settings. No Joy. I know I'm chasing zebras and there is an easy fix. What am I missing?
rrdavis
Re: Tronxy X3
