Help me fix my start Gcode.
Posted: Mon Jan 02, 2017 8:46 pm
by Busdriver101
Hello, I'm sure this question has been answered a million times, but I don't want to change my startup gcode to something all new.
So I need help fixing mine, It should be a pretty simple fix but I can't get it.
I have a Flashforge Creator Pro Dual nozzle
Everything works fine except for waiting for temperature for both Bed and Nozzle.
At the current moment it will wait for bed temp only and then start printing without waiting for the nozzle also.
This is my current Gcode
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T0 ; stabilize right extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 X110 Y-70 E25 F300 ; purge nozzle
G1 X120 Y-70 Z0.15 F1200 ; slow wipe
G1 X110 Y-70 Z0.5 F1200 ; lift
Re: Help me fix my start Gcode.
Posted: Tue Jan 03, 2017 6:08 am
You are correct. There's dozens of threads already about the exact same thing
viewtopic.php?f=9&t=4675&p=20280#p20299
Posted: Tue Jan 03, 2017 7:08 am
by wirlybird
You don't say which nozzle you are actually using with this script and which one the script is for. My guess is you are using the left and it isn't working.
Posted: Fri Jan 06, 2017 4:35 pm
by Busdriver101
CompoundCarl wrote:You are correct. There's dozens of threads already about the exact same thing
This specific link is for only one thing heating at a time, my problem is not that.
My current issue is both bed and left nozzle will start to heat at the same time but it will only wait for bed temp to reach its target and then begin the print without waiting for the extruder temp.
However, I just noticed I'm using the left extruder and have a line in my code that says M133 T0 ; "wait for right extruder" which is not the extruder I'm using..I'll change this to the correct one and see if that will fix my issue.
Posted: Fri Jan 06, 2017 5:41 pm
by horst.w
... and the checkbox in the TEMPERATURE-Tab "Wait for ..." doesn't help?
H.
Posted: Sat Jan 07, 2017 5:19 am
by NitroXpress
I'm not sure, if your Firmware support M133 (stabilize Temperature).
I think M133 is for makerbot Firmware...
Try M109 instead.
Frank
Posted: Sat Jan 07, 2017 8:31 am
by wirlybird
What firmware version are you one? If it is not 7.8 Sailfish then get Flashprint if you don't have it and update the firmware.
