Exterior seam
Posted: Thu Jan 05, 2017 5:44 pm
by Fallen Munk
On a hollow part, I have a seam on the outside while the inside is near perfect. At the end of a layer, the Z retracts and starts the new layer on the exterior perimeter shell. I want it to start on the interior shell instead. I've checked the outline direction "inside-out" box and it does the same seam as the "outside-in" box. No difference. I'm assuming it is because there is only one outline/perimeter shell?
Anyone have an idea how I can get the layer to start on the inside of this hollow part?
Re: Exterior seam
Posted: Fri Jan 06, 2017 3:26 am
by brian442
If you only have a single outline perimeter, than I'm not sure what you mean by "inner seam". The inside-out vs outside-in option controls the order that the perimeters are printed in, so you would need to have 2 or more perimeters to see a difference with that setting
Re: Exterior seam
Posted: Fri Jan 06, 2017 7:23 am
by wirlybird
If I print a cylinder with one perimeter (non-vase mode) then it is not bad but go beyond that and I have the exact same issue and it drives me nuts. I print a cylinder and the seam on the inside is perfect while the seam on the outside is a mess.
I see the exact same behavior as he describes on nozzle travel. It doesn't seem to matter if you print inside-out or outside-in.
Retraction settings, negative restart etc. can help but it never goes away.
I can do the same print on the same printer with Slic3r and the seam is much better (not complimenting Slic3r here!!) because it just prints it differently.
Re: Exterior seam
Posted: Sat Jan 07, 2017 6:07 pm
by Fallen Munk
brian442 wrote:If you only have a single outline perimeter, than I'm not sure what you mean by "inner seam". The inside-out vs outside-in option controls the order that the perimeters are printed in, so you would need to have 2 or more perimeters to see a difference with that setting
That's what I was afraid that setting meant. :( I've adjusted my settings and I've gotten it much better but the interior seam is still slightly better for some reason.
Re: Exterior seam
Posted: Sat Jan 07, 2017 7:15 pm
by georgei
One way that I have found to get rid of the seam is to disable the "Force retraction between layers" in the advance menu.
Re: Exterior seam
Posted: Sun Jan 08, 2017 1:12 am
by Fallen Munk
georgei wrote:One way that I have found to get rid of the seam is to disable the "Force retraction between layers" in the advance menu.
Just tried that based on your suggestion. That looks like scar tissue. Probably because I'm using wipe during retraction. No retraction with wipe is probably a bad idea for this print.
Re: Exterior seam
Posted: Wed Feb 20, 2019 11:41 am
by Hannahmae23
Is there a way to change the outline/ perimeter shell layers to the inside instead of the outside?
Re: Exterior seam
Posted: Wed Feb 20, 2019 3:02 pm
by S3D-Jake
Hannah,
The outline printing sequence is alterable using the Outline direction toggle for inside-out / outside-in toggle in the layer tab.
More on layer tab settings: viewtopic.php?f=8&t=1941
