Page 1 of 2
Wrong extruder
Posted: Thu Feb 13, 2014 4:10 am
by raffo333
Hello, could you please advice me, why my printer uses the wrong extruder,
when i select left it uses the right
Regards
Raf
Re: Wrong extruder
Posted: Thu Feb 13, 2014 9:16 am
by jimc
you probably need to go onto your controller board on the printer and the extruders need to be swapped. just a guess
Re: Wrong extruder
Posted: Thu Feb 13, 2014 9:33 am
by Festus440
You might want to check that the wrong extruder isn't being selected in the g-code startup script (T1 or T0).
Re: Wrong extruder
Posted: Thu Feb 13, 2014 1:39 pm
by raffo333
OK, but do i have to read the gcode ? and where do i have to search ( in the gcode ) ?
Regards
Raf
Re: Wrong extruder
Posted: Thu Feb 13, 2014 1:41 pm
by raffo333
i guess here...
; G-Code generated by Simplify3D(TM) Version 2.0.1
; Feb 13, 2014 at 9:54:52 AM
; Settings Summary
; processName,Process1
; applyToModels,20mm_Calibration_Box
; printMaterial,ABS
; printQuality,Medium
; extruderName,Right Extruder,Left Extruder
; extruderToolheadNumber,0,1
; extruderDiameter,0.4,0.4
; extruderAutoWidth,0,0
; extruderWidth,0.4,0.4
; extrusionMultiplier,0.95,0.95
; extruderUseRetract,1,1
; extruderRetractionDistance,1,1
; extruderExtraRestartDistance,0,0
; extruderRetractionZLift,0,0
; extruderRetractionSpeed,1200,1200
; extruderUseCoasting,0,0
; extruderCoastingDistance,0.2,0.2
; extruderUseWipe,0,0
; extruderWipeDistance,5,5
; primaryExtruder,0
Re: Wrong extruder
Posted: Thu Feb 13, 2014 3:05 pm
by jimc
ok it looks like you have the right extruder as T0 and the left as T1. now look at your controller board on the printer and see how you have the extruders hooked up. i bet you have left extruder hooked to the T0 output and right to T1
Re: Wrong extruder
Posted: Thu Feb 13, 2014 6:24 pm
by Festus440
I'm talking about in the printing process setup window. (Don't have the software here. I can check later) There is a tab where you can have g-code scripts that run when a before a print starts, ends, at layer change, etc. The line usually looks like:
T0 ;select the right extruder
It usually also has code to home the print head, do a purge, etc.
If you had started modifying a process that was originally for the wrong extruder, that line shown above would still be there even though you changed the extruder for layers and support.
Re: Wrong extruder
Posted: Sun Feb 16, 2014 4:45 pm
by JoeJ
What printer do you have? Are you sure you have the firmware settings in the software setup correctly? For example, if you have a Replicator 2X, you need to go to Tools -> Firmware Configuration and choose the MakerBot/Sailfish firmware profile. Then click on the X3G tab and select the Rep2X. If you don't follow those instructions, it won't print with the correct extruder.
More info here:
http://www.simplify3d.com/support/makerbot/
Re: Wrong extruder
Posted: Sun Feb 16, 2014 4:50 pm
by raffo333
my printer is a Wanhao 4x
Re: Wrong extruder
Posted: Sun Feb 16, 2014 5:01 pm
by JoeJ
Yeah same idea. I think the Wanhao D4 is just a clone of the Rep 1 dual. Follow the instructions above, but in your case I think you would select the "Replicator 1 - Dual Extruder" on the X3G tab.
They made things really easy for your since they already include profiles for the Rep1's. You should be able to choose what extruder is used by picking the between the "Replicator 1 Dual (right extruder)" or "Replicator 1 Dual (left extruder)" FFF profiles.
