I'm new to 3D printing, I've only had my printer for about 2 weeks and having pretty good results with the included software. However, many reviews on Amazon keep mentioning Simplify3D as the best software to use for splicing. Before I buy, I need a little more clarification.
1) How well does the software work with the Qidi Tech I 3D printer? From what I understand, it's a clone of the FlashForge printer. Anyone using the Qidi Tech that can share your experiences with me (good and the bad)?
2) Does Simplify3D (natively) export to the .x3g file format (needed by the Qidi printer)? Or is there a manual process required to export to .x3g? I want it as seamless as possible.
3) I want to print some fairly large objects, larger than the print bed (bed size is 200mmx150mmx150mm). Can Simplify3D slice an object that is larger than the print bed into multiple .x3g files to be printed individually? If so, Does it automatically build pieces that allow them to snap together or do you just super glue the resulting pieces?
Thank you for any responses, just doing a little research here before buying.
