poday
Outstanding FFF Request List - for consideration
In looking through the FFF requests, it was helpful to me to create a list of the more recent ones. The list seemed worth sharing. I've seen the consolidated list work well to help track progress for both users and devs. The list can be updated as I see new requests come in or are completed. Let me know if some of these requests are done already or incorrect and I'll fix it.
Requested (not done)
FFF Profile Management
- Add Backup Tool (way to save all FFF profiles as a zip file, as individual files in a folder, or whatever)
- Add Profile Comparison Tool (show only differences between two profiles)
- Add Rename button (rename existing FFF without having to save as new)
- Add Path to "FFF Settings" window on main S3D toolbar (Edit | FFF Settings perhaps?)
- Add Read Only Checkbox (reduces risk of accidental saves of temporary settings to known good profiles)
- Add Button to add new S3D FFF profile from FFF Settings page (with having to go through configuration assistant)
- Add Button to refresh S3D provided FFF profile after S3D update
- Detect and indicate that S3D provided FFF profile changed after S3D update (comparison tool above would help with this)
FFF Profile Enhancements
- Add underhang / overhang specific settings
- Add heat up settings dual extruders
- Add concurrent plate and nozzle heat up (with a delay setting as desired)
- Add notes panel (comments and documentation)
- Set filament diameter as per extruder property
- Re-organize FFF settings by Machine, Material, Quality
Printer Support Requests
- Airwolf Axiom
- Raid3D N1/N2 series
In Progress (devs indicated it's coming)
- TBA
Done and Closed Out (requested and completed or denied due to X)
- TBD
brian442
Re: Outstanding FFF Request List - for consideration
Around half of the things you posted are already possible with the software. So for example, if you want to heat the bed and extruder at the same time, you only have to change one line in your starting script. So it's already possible and easy to do. There's about 10 others on there that are also possible already, but perhaps some people want easier ways to accomplish it (checkbox instead of editing one line in the starting script??)
Also know both those printers are already supported since one is in the configuration assistant, and my friend has the other and S3D already sent him a profile for it that's working well.
