Extruder Offsets
Posted: Thu Feb 13, 2014 1:49 pm
by Jeff
Where is this set? Firmware or Simplify?
I have used both. But prefer to keep my users out of the firmware.
Re: Extruder Offsets
Posted: Sun Feb 16, 2014 10:58 am
by JoeJ
What firmware are you using? Some firmwares allow you to update these offsets with a simple G of M-code. But most of the time, these options are configured by the manufacturers with the default values hard-coded into the firmware. That way us users don't need to mess with it at all :D
Posted: Mon Feb 17, 2014 9:39 am
by Jeff
I am using MARLIN. I was the one that had the following added to MARLIN about a year ago now.
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 31.28} // (in mm) for each extruder, offset of the hotend on the Y axis
This is when I used Replicator G and Skeinforge back in the day.. When I moved to Slic3r and Repetier, Slic3r had the offsets built in.
I will go back to using this if Simplify3D does not support it in their software.
Jeff
Posted: Tue Feb 25, 2014 3:19 pm
by Jeff
I ended up fixing the issue by not using the firmware. For some reason the commands were being ignored.
So what I have done is the following
I added this to my gcode.start file.
M218 T1 X0.0 Y31.28
and added this to the (tools) (firmware) ( General) (Tool Change) T$ F5000
This seems to work just fine.
Posted: Sat Oct 18, 2014 3:13 pm
by Typpa
Hello from Italy,
I just finished building my new printer, but I had the bright idea to put two extruders. I use, Marlin and latest version of S3D but I can not get an offsetting the extruder, I have tried both in Firmaware and S3D. But no I can not change the value of T1 than T0, I have a value of 60 mm on the Y axis Advice? I use S3D with iMac.
I tried as it says Jeff but nothing .... :?:
help, I am on the high seas
The videohttp://www.youtube.com/watch?v=jdI1pF-plpI
Posted: Sun Oct 19, 2014 3:14 pm
by Typpa
solved! enough to put the negative sign to the value M218 T1 X0.0 Y-60.0. - :) Thanks anyway
