I have had a few problems with the print head moving on without benefit of existing filament. For some reason the head stopped extruding. It would be great if I could point to a spot on the build then have the print head return to that spot and continue the build from that point.
I have experimented with backing the print head up over "bad spots" and had the extruder add more filament. It worked.
