How do I move the position where the nozzle primes before pr
Posted: Thu Jan 12, 2017 11:21 pm
by huntleybill
I have a Flashforge Creator Pro. When I use S3D, the nozzle moves to the front right corner and extrudes a few mm of filament before it prints. My issue is, that the nozzle is sitting on the bed when it does that so the feed clicks. What I would like to do is have the nozzle perform this task a few more mm to the right so it is off the bed when it extrudes the filament. How (exactly) do I configure S3D to move the nozzle a little to the right when performing this task.
Thank you
Bill
Re: How do I move the position where the nozzle primes befor
Posted: Fri Jan 13, 2017 4:32 am
This is controlled by gcode lines in the starting script.
See this thread for starters:
viewtopic.php?f=8&t=4889&p=21122&hilit= ... zle#p21122
If you can't work out what to change, post your starting script.....
Posted: Fri Jan 13, 2017 7:59 am
by kabali16
huntleybill wrote:I have a Flashforge Creator Pro. When I use S3D, the nozzle moves to the front right corner and extrudes a few mm of filament before it prints. My issue is, that the nozzle is sitting on the bed when it does that so the feed clicks. What I would like to do is have the nozzle perform this task a few more mm to the right so it is off the bed when it extrudes the filament. How (exactly) do I configure S3D to move the nozzle a little to the right when performing this task.
Thank you
Bill
Are you using the FF Creator Pro 2016 ? If so, try this out ->
viewtopic.php?f=8&t=6183&p=26817#p26817
They prime by drawing a complete line across the bed
Posted: Fri Jan 13, 2017 11:40 am
by huntleybill
OK..I tried Kabali's suggestion re-saved my file to the SD card but the nozzle did the same thing.
Yes, I have the FFCP 2016.
Doug, there also is no line of code saying (purge anything).
Here is my Gcode:
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T1 ; stabilize left extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
M135 T1 ; left tool
G1 X110 Y-70 E30 F300 ; move nozzle
G1 X120 Y-70 Z0.15 F1200 ; slow wipe
G1 X110 Y-70 Z0.5 F1200 ; lift
