bigger and more robust "print from sd window"
Posted: Wed Jan 18, 2017 2:25 pm
by twanskys
sometimes i have variations of gcode with different materials and the window to choose your sd prints cant display enough info.
im surprised its been like this for so long.
Re: bigger and more robust "print from sd window"
Posted: Thu Jan 19, 2017 5:38 am
by brian442
I'm guessing you are talking about how a filename like test_pring_pla_high_quality.gco ends up being listed as just TEST_P~1.GCO. Unfortunately, that's how the firmware works. It can't display the longer names and you have to use the short names to actually start the print. So to fix it, there would need to be some big changes with how the firmware is written.
Feel free to google the 8.3 naming convention for the marlin firmware and you will see what I mean
Posted: Tue Mar 07, 2017 5:17 am
by swsch
Living with 8.3 filenames would be easier if saving to disk would actually use the extension I'm giving the file.
As it is, even if I try to save as "a.g", the actual name on disk is "a.gcode", which then turns on name mangling.
Posted: Tue Mar 07, 2017 6:12 am
by brian442
Just add {EXTENSION "g"} in your post processing script and it will automatically save at .g instead of .gcode
