Hi All,
I've read some of the past supports threads, but think this is worth asking still. I'm open to alternatives or better ways of using the existing software if you have them!
I typically print helmets and masks. I tend to not care about the inside faces, so I don't want supports generated. But, I DO want supports around the outside surface and eye holes typically.
What I am currently doing, is auto-generating supports, at say, 4mm, >50* in normal mode.
Then, I have to go through an manually delete the large chunk of 'internal' supports that generate under the large head cap overhang.
Keeping the question / feature request short - can you add a lasso type tool that will let me delete a bunch of supports over a selected area?
Again, I'm open to "you're doing it wrong" response completely!
