color change mid print
Posted: Fri Jan 20, 2017 3:09 am
I have the Prusa I3 Mk2, I found out that Prusa Research rewrote the M600 gcode, it will do the following steps:
- Stop moving and retract
- Raise the Z by 2 mm and move quickly outside the printbed
- Unload the current filament
- LCD panel will ask you to insert the new filament and confirm when it’s done
- After the initial loading of the filament you will get three options on the LCD 1) Everything is correct and printing may continue 2) Filament didn’t load, try again 3) Extrude a bit more if the color is still tinted by the previous one
- After confirming, printer returns to the original position and continues to print.
Now I made 2 Processes, one will stop at 1,2mm layer hight, the second process will start printing again at 1,2mm layer hight.
Where do I have to insert the M600 code in the script so I can swap the filament during this print process?
